lichtpixel
I’ve just created my first overlay panel. Works quite fine, except that it waits about 5 seconds till it opens the overlay. I’ve set the trigger type to “time delay” and the time delay (MS) to 0 – so I’d expect it to open instantly, which it doesn’t. Can you please help with that?
Also I’m wondering if there isn’t a built in close-button-functionality? I built one myself, but as there are options for other closing methods I assume I’m missing something?
Dominik -
George
Hello.
Regarding the time delay. I see your point, I will ask the team about it. Meanwhile, you can set the delay to
1msvalue (very short), that should fix it.Close button: Yes, you design it inside the panel, then with it selected, go to the right panel in the Advanced Settings, OVERLAY PANEL TRIGGER, select,
Close Opened Overlay Panel.
lichtpixel
Thanks, 1ms works.
Unfortunately “Overlay Panel Trigger” isn’t visible for me. Aria Label is followed by Button type, there’s no Trigger selection.
I’ve added admin credentials to private information, please have a look why it’s missing.
George
You seem to be using v1 block. You would need v2 blocks for that functionality.
lichtpixel
Oh, okay, I see it in V2. Thanks!
George
Ok, no problem!
