Search for: Overlay trigger option not showing in the advanced tab MedAtty LLC January 22, 2026 at 8:57 pm Overlay trigger option not showing in the advanced tab. Alvind January 22, 2026 at 9:12 pm Hi there, One reason the Overlay Trigger option isn’t available could be that the block you’re using is still in V1. To confirm, could you share your site link so I can take a closer look? MedAtty LLC February 1, 2026 at 8:24 pm medatty.com Alvind February 1, 2026 at 9:45 pm I can confirm that your site is still using the V1 blocks, which explains why the Overlay Panel trigger option is not available. You will need to use the V2 blocks in order to use that feature. Please refer to this article for guidance: https://learn.generatepress.com/blocks/block-guide/generateblocks-1-x-to-2-0/ Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic.
