Override Fluent Forms style with GeneratePress Customizer style
  • Hi. I am trying to drive the colors of the form fields in Fluent Forms with the colors defined in the Customizer.
    Problem is that GP is generating CSS like this for when I click into a textbox (focus):
    input[type="text"]:focus, input[type="email"]:focus, input[type="url"]:focus, input[type="password"]:focus, input[type="search"]:focus, input[type="tel"]:focus, input[type="number"]:focus, textarea:focus, select:focus {
        color: white;
        background-color: black;
        border-color: black;
    And Fluent Forms is generating CSS like this.
    .ff-default .ff-el-form-control:focus {
        background-color: #fff;
        border-color: var(--fluentform-primary);
        color: var(--fluentform-secondary);
        outline: none;
    So it looks like Fluent Form’s specificity or order in the cascade is winning out.
    Ideally, I would love to append “.ff-default .ff-el-form-control:focus” to the selectors that GeneratePress generates so that it reads the global colors defined in the Customizer.
    The only solution I have now is to write custom CSS that overrides both Fluent Forms’ and GeneratePress’ settings. Any alternate ideas? Thanks for your time.
    Looking at Fluent Form’s documentation, it seems there is an option to Inherit Theme Style:
    https://fluentforms.com/docs/official-form-styler-of-fluent-forms/#1-toc-title
    Could you try enabling that option to see if it resolves the style overrides?
  • Hi Alvind! That did the trick. I would have never found that. Is that a common feature with form plugins? Thank you so much for your response.
  • Glad to hear that!
    I think so – I’ve been using Gravity Forms, and it has that kind of setting, so I assume most form plugins would offer something similar.
