I want to override global container padding in one container. The padding settings in the right sidebar do nothing. The additional CSS box does not show in the right sidebar for this container. Inspect shows no ID of any kind for the container. I gave the container a name but this does not show in DevTools either. How can set the padding for this one container?
George
Thanks for the credentials, they are not working, though.
As far as the issues with the blocks, those are core blocks you are using, they are not part of GenerateBlocks. Is your intention to use the blocks included in GenerateBlocks?
Credentials are updated now. Which GenerateBlock block or element would I use to show five excerpt titles in this block only?
I am not sure what you mean by “show five excerpt titles in this block only”?
Can you explain some more?
