I’ve created a related posts custom block but the read more button that gets injected into the code doesn’t have any padding on it. See the bottom of this page. Just wondering how I add padding to it.
Select the container that wraps the excerpt and the Read More button. Under the Layout settings, apply the following configuration:
Display: Flex
Flex Direction: Column
Row Gap: 30px -
Please see screenshot to make sure I’m selecting the right container, but when I do select that container and apply the settings it seems to put spacing between the heading and the exit but not the button.
Could you try applying the configuration to the Post Excerpt block?
That did the trick. Thank you Alvind.
You’re welcome, glad to hear that!
