ch18639
I can’t work out why there’s extra padding at the bottom of this ‘Betdaq’ container. I’ve set the padding to 25px all the way around but there’s double at the bottom: https://www.thesurebettor.com/betting-exchanges/
Any help would be greatly appreciated.
Charles
Hi Charles,
I would recommend rebuilding that section using GB’s Grid block instead of the WP core columns block:
https://docs.generateblocks.com/article/grid-overview/That way you will have complete control over using the Spacing options:
https://docs.generateblocks.com/article/spacing-options-overview/Let me know if this helps 🙂
ch18639
Hi Leo,
I’ve created a new grid section with a similar layout. I still have the padding underneath the image which I can’t seem to get rid of with CSS. There’s also now padding on the left hand side.
Charles
Hi Charles,
Try setting the bottom margin of the GB Image Block to 0.
If that doesn’t work, let us know. You have a custom CSS adding the spacing. We may need to revise that code.
ch18639
Hi Fernando,
That seems to have worked for the bottom padding but there’s still padding on the left hand side of the image.
Charles
Try removing the Grid Horizontal gap, and the add spacing to the Container Blocks instead.
ch18639
Great, thanks Fernando
You’re welcome, Charles!
