Hey Generate team,
After updating to GB 2.1, the page editor is no longer full-width.
I’ve included before and after images in the private info for demonstration.To clarify, my sites all have a Layout Element with Content set to ‘Full Width (No padding)’.
As expected, the page editor UI is thus usually full-width, as in the before image.After the update, it’s being limited by the global container max-width:
body .wp-block { max-width: var(--content-width); }and
html :where(.wp-block) { max-width: 840px;How can I revert it to the previous behavior, so that the editor is full-width when the content layout is set to full-width (no padding)?
Thanks kindly
(Also, the new 2.1 features are absolutely fantastic – thanks as always!)
This could be a bug. If you switch to mobile view and then back to desktop view in the editor, does the desktop width appear as expected (full width)?
Hi Alvind,
Great idea! Swapping to mobile view and back to desktop made the editor full-width again.
Great to know there’s a workaround for the time being – looking forward to the bugfix. Thanks in advance!
Glad to hear that! I’ll raise an issue for this so it can be patched. Thanks for the information.
Stefanie
Hi FY
I would be very grateful if you could tell me which new features you mean.
Thank you! -
Thank you!I’m really enjoying the new styles dot-indicator system – just a general improvement on the block options/controls that makes it much easier to understand what’s going on with my styles at a quick glance.
The improved editor performance is also noticeable. Also very happy to see that nested Accordion blocks are fixed.
Here’s the full changelog: https://generatepress.com/category/changelog/
And here’s the blog post diving into the changes: https://generatepress.com/introducing-generateblocks-2-1/ -
Stefanie
Thank you!!
And here’s the blog post diving into the changes: …
Thank you so much, I hadn’t even read that! It’s a shame that GP’s blog posts are so hidden!
Sorry for the inconvenience here! We’ll be releasing a GP Premium fix on Monday to fix this.
For now (until GP Premium 2.5.3), you can use this function:
add_action( 'enqueue_block_editor_assets', function() { global $generate_elements; if ( ! is_array( $generate_elements ) ) { $generate_elements = array(); } $layout_element = array_filter( $generate_elements, function( $element ) { return $element['type'] === 'layout'; } ); $layout_element = array_values( $layout_element ); if ( ! isset( $layout_element[0]['id'] ) ) { return; } $id = $layout_element[0]['id']; $content_area = get_post_meta( $id, '_generate_content_area', true ); $content_width = get_post_meta( $id, '_generate_content_width', true ); $content_width_value = ''; if ( 'full-width' === $content_area ) { $content_width_value = '100%'; } if ( $content_width ) { $content_width_value = absint( $content_width ) . 'px'; } if ( $content_width_value ) { wp_add_inline_style( 'generate-block-editor', '.editor-styles-wrapper {--content-width: ' . $content_width_value . ';}' ); } }, 50 ); -
Thanks for that, Tom! Really appreciate it. Will keep an eye out for 2.5.3 also.
No problem! GP Premium 2.5.3 has been released, so you can remove the above function once you’ve updated.
Thanks for reporting the issue!
