Plamen PS
Hi Guys,
I want to create Page like on the examples. Grids with a models and names underneath. How to do that?
Best,
Plamen -
George
Hi Plamen,
You can build this kind of layout easily using a Container block in GenerateBlocks set to a grid.
Here’s how:
- Add a Container block and set its layout to Grid. Set it to 3 or 4 columns depending on how many you want per row.
- Inside the Container, add a child Container for each model. In each one, place an Image block with the model’s photo and a Headline or Text block with their name underneath.
- For a clean, uniform look, set your images to a consistent aspect ratio (like 2:3 for portrait shots), center the names, and keep padding minimal.
That’s it — duplicate the child Container for each new model and swap out the image and name.
Plamen PS
There is no Grid Layout for the Container.
George
Select a container and look on the right, do you see this?
Plamen PS
I’ve got it but is it possible the grids to be constraint. Meaning like a container with specific fixed image aspect ratio, and to not have to change the dimensions for every image? Meaning the image containers to be always 3 x 4 and to not have to resize the images all the time? Check the last link to see that different images show up differently and grids are not aligned.
George
Before I answer, is there a reason you are using the V1 GB blocks? Since you are just starting your site, GB v2 blocks are more flexible. You could go to GenerateBlocks -> Settings and disable the Use version 1 blocks toggle.
You would have to recreate the grid. Otherwise, confirm that you want to work with GB v1 blocks and I will reply accordinlgy.
Plamen PS
Check my last Screenshot.
George
Can you please recreate the
/main-boardgrid with the new blocks? Insert a container and set it to grid with the right amount of columns.
Plamen PS
Okay, I created a grid with Generate Blocks V2 but I like the V1 better. Check the last 2 Links. The new block grid is at the bottom – the 3rd one.
How to gain access to these settings about the gabs in blocks V2?
Check the last screenshot.
And why you wanted to use blocks V2?
George
V2 blocks are more flexible than V1 with more option which could be of help in the future, you won’t have to enter as much CSS. But, you can switch to v1 block if you want, let me know if you do.
One of the V2 aspects is the GB image. You can replace the core images you have in your grid with GB images instead (you can transform the core image to a GB one). Then you could set width to
100%, height toauto, object-fit tocoverand aspect-ratio of3 / 4or similar, all from the block settings. -
Plamen PS
George
Just to confirm, the last screenshot you sent show a GB V1 grid. For a v2 grid (the one you have at the bottom), transform the core images to GB images from the toolbar as shown in the screenshot.
Let me know when done.
Plamen PS
Didn’t understand the steps and why I do it? What to do?
George
The idea is to be able to improve the aspect ratio for the images, correct? Then, insert the images that do not have the same size inside the GB v2 grid. But instead if inserting a core WordPress image block, insert a GenerateBlocks image block. Maybe that would be easier.
Is that clear?
Plamen PS
Not super clear. Still not seeing things through. Can you share again the steps or give examples?
Also, can I bring the gap slider on my last screenshot to blocks V2? I need those settings.
George
Gap is controlled by those settings here:
You can add images to grid container like I show you in this video. I also show you how to adjust spacing.
