Anonymous
I’m experiencing problems with several websites, using Generate Press (2.4.1) and Generate Blocks Pro (1.7.1) since I updated these plugins.
The page contains some (simple) reusable blocks. The page is frozen when I want to edit it. The reusable blocks don’t load. I can’t edit the page which causes nightmares, my business relies on GP.
If I create a new (test)page and when I try to add an reusable block, I’ll have the same issue. Page freezes.
Please help…
Kind regards,
Martijn -
it sounds like an issue with a re-useable block.
Is it specific re-useable blocks causing the issue ? -
Anonymous
Hi David,
Yes. All reusable blocks are causing this issue when I try to add them to a (test)page.
Desperately hope you can help me out.
Kind regards
Martijn -
If you go to Dashboard > Appearance > Patterns.
Can you edit any of the Patterns there ?If so can you make a small edit to one , and re-save it. Then test if that causes an issue.
Anonymous
Hi David,
I’m able to edit the pattern via Dashboard > Appearance > Patterns.
I’ve saved the alltered patterns.If I now open the page, the page loads and is editable.
No more freeze. Phew!Does this mean I need to alter all my reusable items on every site?
Kind regards,
Martijn -
Well first off – thats good to hear!
I can’t say if you will need to edit other sites patterns
It seems to be a very random bug where some patterns get messed up after the WP 6.6 update
We have had a couple of support topics here relating to it, and they were resolved by editing and resaving them.So if the other sites are ok, then leave them be 🙂
Anonymous
Hi David.
Thanks for the support and advice.
I’m so glad that this workaround helps.
You saved my life.Kind regards,
Martijn -
Glad to be if help!
