LinuxWolf
Hi, I had built a form using Element (generate_before_footer). It used to look good but now breaks.
when I am logged in, the footer elements looks okay but when I check it in incognito mode; it doesn’t look good. I have attached few images with the doc file I shared.
I use gp default copyrights footer, also have generate_before_footer for other footer, and generate_before_footer again for form footer.
LinuxWolf
I just tested and found, it’s cache plugin issue.
I use lightspeed cache. Is there a way to avoid this issue while the cache plugin is active?
You can try setting the CSS print method to inline at appearance > generateblocks > settings.
LinuxWolf
I haven’t tasted it but deleted the cache plugin. I might open it again later. Thanks for the support.
OK, no problem!
