Pagination doesn’t load at top of page
  • Hi!
    I’m using a query with standard pagination, inherited from the template, for the page linked below. Currently when I click on the next page button, the second page of image load, but it doesn’t move at all (it doesn’t scroll the page back up to the top of the results, for example). I’d love for this behavior to be added to the pagination, is there a way to do that and still have real urls for different page results (see second link below)?
    Elisabeth
    With the standard pagination type, the page should refresh every time you click on the page number.
    So this behaviour is not normal. I wonder if there’s another plugin that is interfering with this.
    Can you disable all other plugins to test?
  • Ok thanks, that helped; I deactivated all the plugins I could except for the basic Generate Blocks, GPBlocks Pro and GP and ACF ones, and the plugin that seemed to be causing the issue is Search & Filter Pro – GenerateBlocks Extension – I’m guessing I should follow up with them then, right?
    Elisabeth
  • It’s good to know they have a specific GB extension add-on 🙂
    Yes, please follow up with them. If you don’t mind, we’d like to know what they respond. Thank you!
  • Ok I’ll keep you updated.
  • It’s strange because pagination works fine on page 1 below, but not on page 2, but they are using the same query type.
  • I think it might be related to some JS of the addon.
