Pagination isn’t working
  • Pagination in blog archive page isn’t working … I can you get me a solution to the issue. see site (https://timelsspersons.org/)
    I took a look at your page source and found the issue — there are two Query Loop blocks on your Biographies page. The second one isn’t rendering any visible content, so it’s easy to miss, but it’s interfering with pagination and causing the same posts to load on every page.
    To fix it, open the page in the editor and switch to List View (the three-line icon in the top toolbar). Look for a second Query Loop block — it’ll be just below the first one. Delete it, then save and test pagination again.
  • A big tanx solved…
  • Ok, no problem!
