Pagination sequence error
  • Hi. Why when we check via screaming frog we had this error?
    How to solve this issue?
    We can follow the suggestion in the ‘How to fix’ section of your screenshot. To do that, add this snippet:
    add_filter('paginate_links_output', function($output, $args) {
        $output = str_replace('class="prev', 'rel="prev" class="prev', $output);
        $output = str_replace('class="next', 'rel="next" class="next', $output);
        return $output;
    }, 20, 2);
  • Hi we already put this code via code snippet as you suggest
    Please recheck again. Because we check the error still appear?
  • As you can see, the rel="next" and rel="prev" attributes have been added to the pagination links, just as suggested: https://postimg.cc/BLtnBqJ8
    Not sure why Screaming Frog did not pick up the changes, but you may need to give it a little time and retest.
