Parallax doesn’t work
  • Hi everyone,
    I’m trying to add a parallax effect in a container, inside the homepage.
    I read this topic https://generatepress.com/forums/topic/parallax-effect-using-generatepress-theme-and-generateblocks/ and I used that method but when I launch the page, I see only a blank background in the container.
    How can I solve it?
  • Hello. Do you have the GenerateBlocks plugin installed?
  • Hi, yes I have.
  • You need to add a background image and set ATTACHEMNT STYLE as FIXED.
    Background image as Fixed attachement style
    Click the three dots at the top right of the page and switch to Code editor. Copy the following code and paste it in your page. Switch back to Visual editor to view the block.
    Switching between Code and Visual editor
    <!-- wp:generateblocks/element {"uniqueId":"1789d4c8","tagName":"div","styles":{"backgroundImage":"url(/wp-content/uploads/2021/07/technology.jpg)","backgroundSize":"cover","backgroundRepeat":"no-repeat","backgroundPosition":"center","backgroundBlendMode":"normal","paddingTop":"14rem","paddingBottom":"14rem","backgroundAttachment":"fixed"},"css":".gb-element-1789d4c8{background-attachment:fixed;background-blend-mode:normal;background-image:url('/wp-content/uploads/2021/07/technology.jpg');background-position:center;background-repeat:no-repeat;background-size:cover;padding-bottom:14rem;padding-top:14rem}"} -->
    <div class="gb-element-1789d4c8"><!-- wp:generateblocks/element {"uniqueId":"b8624c98","tagName":"div","styles":{"maxWidth":"var(\u002d\u002dgb-container-width)","marginLeft":"auto","marginRight":"auto"},"css":".gb-element-b8624c98{margin-left:auto;margin-right:auto;max-width:var(\u002d\u002dgb-container-width)}"} -->
    <div class="gb-element-b8624c98"><!-- wp:generateblocks/text {"uniqueId":"278b26ac","tagName":"p","styles":{"textAlign":"center","backgroundColor":"var(\u002d\u002dbase-3)","paddingTop":"2rem","paddingRight":"2rem","paddingBottom":"2rem","paddingLeft":"2rem"},"css":".gb-text-278b26ac{background-color:var(\u002d\u002dbase-3);text-align:center;padding:2rem}"} -->
    <p class="gb-text gb-text-278b26ac">Content could go here...</p>
    <!-- /wp:generateblocks/text --></div>
    <!-- /wp:generateblocks/element --></div>
  • It works, thanks!
  • No problem!
