shaunkillian
Hi
How do I create a parallax effect for a container’s background image in the new GB?
Cheers
Shaun -
Hi Shaun,
Do you have an example of the parallax effect you’re trying to replicate?
Some parallax effects require JavaScript depending on the desired behavior. If you can share an example, we can determine whether it can be achieved within the editor alone or if custom CSS is needed.
Let us know.
shaunkillian
Hey Alvind
It used to be a simple setting in GB, where you set a background image to fixed. See below example. -
Ah, okay – you can see here how to set that up in the V2 blocks: https://cln.sh/ZxMTgG8rQlWBFffxgkyT
shaunkillian
Thx Alvind
I changed the setting, but it isn’t producing the effect -
Is it the first section on the page where you added the attachment type? If so, I inspected the section, and the background attachment does not appear to be applied.
shaunkillian
Thx
No problem 🙂
