Parallelogram Shape in GenerateBlocks Without Custom CSS
    I am working on a project using GenerateBlocks and would like to create a parallelogram-shaped container similar to the one in the attached image ( https://imgur.com/BbTrNW9 ). Is it possible to create this kind of shape natively in GenerateBlocks or GenerateBlocks Pro without using custom CSS?
    Thank you for your time and support!
    Yes, you can with GB Pro.
    Select the container with the blue background, add effect > transform > skew > -20deg.
    However, this will transform the content inside the container as well, so you need to select the content inside the container and set another skew effect with 20deg for them to offset the parent content’s transform.
