Pattern Library Not Working
  • Hello there, it seems when I click on my pattern library nothing seems to happen. it seems I just keep getting a spinning wheel like on this example below mentioned by one of your other users. https://generate.support/topic/pattern-library-not-working/
    I use xcloud for my WordPress hosting and I’ve reached out to them for help. thanks,Rodney
  • Hi Rodney,
    In that previous ticket you referenced the root cause turned out to be the site’s REST API failing at the server level, which the pattern library depends on. Yours may well be the same thing, but the symptoms aren’t identical (that user’s library opened but rendered empty, yours doesn’t finish loading), so let’s confirm before pointing xCloud at anything specific.
    Could you grab two things for us?
    1. Go to Tools → Site Health → Status and let us know if there are any errors listed, particularly anything mentioning the REST API or loopback requests.
    2. Open the editor, press F12 to open your browser’s developer tools, switch to the Console tab, then click to open the pattern library. Once the spinner appears, copy anything that shows up in red. If you can also switch to the Network tab and look for a request that’s either stuck as pending or returning a 4xx/5xx status, a screenshot of that would tell us a lot.
    Could you also confirm your GenerateBlocks and GenerateBlocks Pro version numbers?
  • Thanks, George for reaching out to me about this issue. Here is what i found so far based on the instructions you sent.Please see below.
    Loading failed for the <script> with source “https://stats.wp.com/w.js?ver=202640”. This site appears to use a scroll-linked positioning effect. This may not work well with asynchronous panning; see https://firefox-source-docs.mozilla.org/performance/scroll-linked_effects.html for further details and to join the discussion on related tools and features!
    JQMIGRATE: Migrate is installed, version 3.4.1
    GenerateBlocks 2.4.1 GeneratePress Premiun 2.5.6 and GenerateBlocks Pro 2.7.1 version numbers?
    /home/rodney/Desktop/Pattern Library Screenshot from 2026-10-04 10-19-22.png
    /home/rodney/Desktop/Network Screenshot from 2026-10-04 10-22-28.png
    /home/rodney/Desktop/Screenshot from 2026-10-04 10-12-28.png
    I also disabled the youtube adblocker but it still didn’t change anything. Let me know what you find George. Thanks, Rodney
    Your screenshots didn’t go through. You can use a service like postimages to embed them here.
    If possible, could you provide a temporary admin login to the site so we can take a closer look at the issue?
    If so, please use the Private Information section to provide the credentials. You can edit your first post and add them there.
  • the site is still in demo mode as I’m working on it.
  • I’m unable to log in due to an issue with the Cloudflare CAPTCHA on the login page. It won’t let me get past the verification.
    Would it be possible to temporarily disable it so I can log in?
  • Okay, try it again. thanks
  • I was able to log in and identify what is blocking the pattern previews.
    The preview response contains conflicting X-Frame-Options values: SAMEORIGIN and DENY. The browser therefore blocks the previews, leaving the loading wheels visible.
    Could you forward this to xCloud support and ask them to locate the source of the DENY header? GenerateBlocks needs its preview responses to allow same-origin framing, with a single X-Frame-Options: SAMEORIGIN header.
    The affected URL is:
    https://ragpickerbooks.1wp.site?gb-template-viewer=isolated
    Please ask them to check both gb-template-viewer=isolated and gb-template-viewer=1, then clear any affected caches. Once corrected, we can check the pattern library again.
  • Hi Alvind, I reached out to Xcloud like you requested with the following information and as per your noticing here is the conversation with xcloud support. I spoke with Linda, who was awesome.
    Thanks for flagging this. The reported checks show conflicting X-Frame-Options headers: SAMEORIGIN and DENY. DENY blocks iframe previews, even when the page itself returns successfully, which explains the GenerateBlocks preview issue.
    To help us assist you more efficiently, please create a support ticket using the following link:
    https://app.xcloud.host/support/all-tickets
    Kindly make sure to include all relevant details and grant the necessary permissions. (Support access and SSH )
    Creating a ticket allows us to properly track and manage each issue individually, especially when there are multiple concerns, ensuring nothing gets missed and everything is resolved smoothly.
    Once the ticket is submitted, our team will take it from there and assist you right away.
    Thank you for your cooperation. I submitted the ticket for repairs and will get back with you as soon as I hear anything. Thanks, Rodney
  • Hi Alvind, I’m pleased to say that xCloud was able to resolve the issue for me. Thanks, Rodney
  • You’re welcome, glad to hear that!
