Pattern Possibly Corrupted
  • fergusoncomputers
    I am unable to edit a page on my website, and I suspect it’s related to a pattern in use on the page.
    When I try to edit the page, the pattern tries to load but then the page freezes and the browser tab crashes. I’m able to open the pattern by itself within the Local Patterns library, but I’m not able to insert the pattern on a new page without the page freezing & crashing.
    I am using a staging site to troubleshoot the issue. I’ve deactivated all plugins except for GeneratePress Premium, GenerateBlocks, and GenerateBlocks Pro. I have WP Debug turned on, and caching is currently turned off.
    Here is a screen recording that demonstrates the issue: https://www.loom.com/share/99f3e5f7148746089dd8ce7d3a0e71ad?sid=a9eeb72b-43e7-49a5-a6bf-c5f3ffcb5a3b
    this is a known WP bug, the workaround is to edit the local pattern, make a small change and save, it should fix the issue. Then you can edit the pattern again to revert the change.
    Let me know if this helps!
  • fergusoncomputers
    Got it! That resolved the issue. Thank you for your help. 🙂
  • You are welcome   🙂
