Shibumi
I noticed an issue concerning patterns.
I created one and saved as synced pattern. It correctly goes in the “my patterns” section, but what I try to insert it in an other page it will freeze the page.Apparently it conflicts with the “Code Snippets” Plugin.
Don’t know if it’ their issue or yours, but still I thounght it could be useful to point it out.
Best,
Lorenzo -
Shibumi
Errata corrige,
it seems to be conflicting with the WPForms Lite plugin (the pattern has a form in it). -
if you only have the form in the pattern, with no other blocks, does the issue still occur?
Shibumi
Hello Ying,
I tried and with just the form in the pattern it has no issues.Best,
Lorenzo -
what other blocks do you have in the problem pattern ?
Shibumi
Hi David,
I have containers, headings and images.
I’ve added the url to edit the incriminated local pattern in the private info. -
If you make a small edit to the problem pattern and save it.
Does the issue go away ? -
Shibumi
I tried (I edited the green heading), but the problem still occurs.
What happens if you create a new pattern that looks the same as the old one ?
as we have seen some issues where a synced pattern gets messed up in the database -
Shibumi
Hi David,
I tried to create an other one like the first one and it freezes. -
Can you try disabling all plugins except GB, GB Pro and GP Premium, then give it another try?
Shibumi
Disabling all plugins except GB, GB Pro and GP Premium works. The thing is that there is a conflict with WPForms plugin. If I disable everything except GB, GB Pro, GP Premium and WPForms Lite the problem still occurs.
So it’s an issue of WP Forms, let their support know, they might already have a fix.
