Populate mega menu with navigation items
    We’re building a Mega Menu for a client using GB Pro.
    Is there not a way to populate a mega menu with navigation items fetched from the navigation located in the Appearance > Menus in the WP controlpanel?
    Or is the only way to manually create each menu item (again) inside the Mega Menu?
    Thanks.
    BW P.
    That’s correct — the GB Pro Mega Menu doesn’t pull from WordPress navigation menus. The mega menu panel is essentially a block editor canvas, so the menu items and layout are built manually using blocks (buttons, headline links, grids, etc.).
    There’s no way to dynamically populate it from an existing menu registered in Appearance > Menus.
    It does mean duplicating the structure, but the upside is full control over the layout — you can include images, icons, descriptions, and multi-column layouts that wouldn’t be possible with a standard menu.
    Thank you for your reply.
    Good to know.
  • Ok, no problem!
