Popup size will be applied?
    I created two pop-ups, copying and customizing the first one. Now the size change of the second pop-up is being transferred, even though pop-up 1 had a size of 600px and pop-up 2 had a width of 1200px. Why is that?
    Thank you
    I’m not sure I fully understand the issue. I checked both popups, and they appear to have different widths set under the Sizing settings.
    Let me know if I’m misunderstanding something.
  • Yes, that’s right…
    but when you click on these pop-ups, both seem to have a width of 1200px, even though one should only be 600px wide?
    1200px width:
    click on the INFO button on the landing page, the overlay fits so far
    Screenshot: https://postimg.cc/G8qrvCtC
    600px width:
    The PopUp program appears after loading the website and also when clicking “ZEIGEN.” The entire flyer should be visible, which it would be at a width of 600px.
    Screenshot: https://postimg.cc/K3S77dH0
    Can you try duplicating the overlay panel grid you have for each popup and then removing the original one? Could be an issue with conflicting block IDs (when you copied one to create the other one).
  • Right George, that was the problem… Thanks for you tip.
  • Ok, good, no problem!
