Post Archive Sorting by Modified not Published Date
  • The posts in my archive seem to be sorted by last modified versus the publish date. Is this a setting somewhere?
  • Hi Justinfm,
    It should be ordered by Published date by default.
    Do you have any custom snippets? Can you check if one is causing this?
    If there isn’t try adding this snippet:
    add_action( 'pre_get_posts', function($query){
    if ( !is_admin() && ( $query->is_home() || $query->is_archive() ) && $query->is_main_query() ) {
            $query->set( 'orderby', 'date' );
            $query->set( 'order', 'DESC');
  • I tried this, but it didn’t work.
    I should note, it seems like it’s only happening when you click on a category. The search function brings up the posts in correct date order. I’m not using tags, so I don’t know if it does it in tags.
  • I updated the code I provided to include archive pages. Can you test that?
  • That code worked.
    Thanks,
    Justin
  • You’re welcome, Justin!
