Ive been searching the forum but I cant find the step by step on how to do this.
I would like to add the post date + update date on each post on my blog. How can I achieve this?Could you kindly send me the step by step and where I should add the code? Im not a programmer.
THank you 🙂
Can I see one of your current post? I need to see if it’s using the default theme date, or an element.
Im attaching below.
So you are using a block element – page hero for the title/post meta section.
You can edit this element and duplicate the headline block (published date), then select the updated date for the new headline block.
