Post Editor is Full-Width
  • I have a problem with full width editor, i got this problem when activate GP Premium. The writing area is too wide and no padding with the monitor.
    full-width
    But the problem didn’t show when i create new post. its only for edit post.
    new post
    Any suggestion to fix that? i’ve reinstall gp premium, generatepress, but can’t fix that
    Can you try temporarily deactivating all other plugins except GP Premium and GenerateBlocks to rule out any potential plugin conflict?
  • Yeah I do, everything is good till I activated the generateblock pro plugin.
  • Do you currently have a Layout element active on the site that sets the content area to Full Width?
  • Yeah i have this. When I disable the element everything is work. anything can do with this?
    Full Width Element
    because when i disable the element my layout is broke
    https://i.postimg.cc/Kvt1MXR8/screenshot-Nd-288.png
  • Okay, so that is the expected behavior. When you set the content to full width, the editor will also display in full width.
  • so i need disable this element to fix ? and adjust the front end layout with css?
  • Yes, if you want to do that.
