birdhousedigital
I’m using your php snippet (with updates for GB 2.0) to sort my posts by acf date.
I have another acf date field, which is the end or expiry date. Do you have a snippet or any way to expire the post, ie no longer show it in the query loop, based on an acf date field? -
Try replacing the snippet with this one:
add_filter('generateblocks_query_wp_query_args', function ($query_args, $attributes) { // apply filter if loop has class: order-by-date if (! is_admin() && ! empty($attributes['className']) && strpos($attributes['className'], 'order-by-date') !== false) { // Get today's date in the format that matches your end_date field $today = current_time('Y-m-d'); // Set up the meta query to exclude posts where end_date matches today $meta_query = array( 'relation' => 'AND', array( 'key' => 'event_end_date', 'value' => $today, 'compare' => '!=', 'type' => 'DATE' ) ); // Add or merge with existing meta_query if any if (isset($query_args['meta_query'])) { $query_args['meta_query']['relation'] = 'AND'; $query_args['meta_query'][] = $meta_query[0]; } else { $query_args['meta_query'] = $meta_query; } // Keep the original sorting by event-start_date $query_args = array_merge($query_args, array( 'meta_key' => 'event-start_date', 'meta_type' => 'DATE', 'orderby' => 'meta_value', 'order' => 'ASC', )); } return $query_args; }, 10, 2);
birdhousedigital
Thanks Alvind,
I changed compare: ‘!=’ ➝ compare: ‘>=’ and it works perfectly! -
Ah yes, that was my mistake. Glad to know it’s all sorted!
