Post/grid layout and look
  • I was trying to see if I could replicate the post and grid layout in generate press, like the layout in the attached link. The individual posts have a raised look or shadow effect (box around each post) that makes each post stand out. Thank you!
    yes it is possible, as that site is built with GeneratePress and GenerateBlocks.
    Can i see your site and where it is you want to apply the shadow ?
  • Thanks David, below is a link I would attempt to place this effect on with a photo inside a box as pictured in the sample page.
  • Try this CSS:
    .generate-columns-container .inside-article {
        display: flex;
        flex-direction: column;
        padding: 30px;
        background-color: #fff;
        box-shadow: 3px 3px 12px 0 rgba(0,0,0,0.1);
    .generate-columns-container .no-featured-image-padding  .post-image {
        margin-left: -30px;
        margin-right: -30px;
    .post-image-above-header .generate-columns-container .inside-article div.post-image {
        margin-bottom: 0.75em;
    .generate-columns-container .entry-summary {
        margin-top: 0.75em;
        margin-bottom: auto;
        font-size: 0.8rem;
    .generate-columns-container .read-more-container {
        display: none;
  • Hi David, that looks amazing,thanks a lot for your help.
    As a followup is there a way I can replicate this on other pages? For instance, I want to add it (the shadow effect on post/grid) to the page below as well and a few others, but is there a way I can make a simple change so I don’t have to bother you all?
  • Hmmm…. you could try this:
    .gb-post-grid-item {
    .gb-post-grid-item .gb-block-post-grid-text {
        padding: 0 30px 20px;
  • Amazing! Thank you David!
  • You’re welcome
