chetanpatil
On my post : http://ruminatee.com/personal-finance-added-to-california-high-school-graduation-requirements/ I am trying ti display the published date and modified date as well. I can see the published date but modified date and modified only both are not working. It displays a number: https://prnt.sc/1WIuW_WW8Z67
I have modified this post and it has this date.
My settings are https://prnt.sc/cYAX4fp4yH_c
I have followed this article as well: https://learn.generatepress.com/blocks/dynamic-tags/post-date/
Nothing is working.Please let me know how we can fix this.
Regards
The issue is with the Date Format where you’ve used “g” as the return format. The “g” format specifier represents the 12-hour clock without leading zeros (1 to 12). This is why the output shows only a single digit for the hour.
You can leave the Date Format field blank to use the default date format.
chetanpatil
Ok.
How we can make this block conditionally visible?
Means if there is a update date then only this block should appear otherwise should not. -
1. add a class to the published date, eg.
published-date.
Adding CSS class(es): https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/2. add a class to the updated date, eg.
updated-date.
Adding CSS class(es): https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/3. add a class to the parent container of the 2 text block, eg.
post-meta-container.
Adding CSS class(es): https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/4. add this CSS:
.post-meta-container:has(.updated-date) >.published-date { display:none; }Adding CSS: https://docs.generatepress.com/article/adding-css/
Let me know if this helps!
chetanpatil
Ok Thanks. Can you tell me why the below post is showing the published date and updated date as same?
http://ruminatee.com/true-grit-rated-pg-13-for-western-style-justice-violence-and-characters-with-bad-teeth-and-slobber/Regards
That means the post hasn’t been modified since it was originally published. Try editing the post and making a small change to confirm this.
chetanpatil
Ok I understand what you are saying but if the post is published and not modified then second block should be automatically hidden. This is weird.
Isn’t it? -
You need to select modified only instead of
modifiedfor the modified date, otherwise it will show the post date if no modified date.
https://app.screencast.com/fybN0TgmNUJRI
