Post-nav links
    How can I remove a specific post category from the following rule:
    add_action( ‘after_setup_theme’, ‘tu_category_specific_post_navigation’ );
    function tu_category_specific_post_navigation() {
    add_filter( ‘generate_category_post_navigation’, ‘__return_true’ );
    Thanks for your help,
    Philippe
    Try this:
    add_action('wp', 'custom_generate_category_post_navigation');
    function custom_generate_category_post_navigation() {
    	 if ( !in_category('cat-x')) {
    	    add_filter('generate_category_post_navigation', '__return_true' );
    Replace the cat-x with your category slug: https://codex.wordpress.org/Conditional_Tags#A_Category_Page
    Let me know if this helps 🙂
  • Hi Leo,
    I replaced cat-x with ‘articles’ (the concerned post category) but it does not work.
    Try this snippet:
    add_action('after_setup_theme', function() {
        add_filter('generate_category_post_navigation', function($display) {
            // List of category slugs to exclude
            $excluded_slugs = ['articles'];
            // Get the current post's category slugs
            $post_categories = get_the_category();
            $post_slugs = wp_list_pluck($post_categories, 'slug');
            // Check if the current post is in any of the excluded categories
            $is_excluded = !empty(array_intersect($excluded_slugs, $post_slugs));
            // If the post is in an excluded category, return false to disable navigation
            // Otherwise, return the original value
            return $is_excluded ? false : $display;
  • philipperoussel
    Hi Alvin,
    I did the following. It still does not work. No big deal if that cannot be achieved.
    $excluded_slugs = [‘articles’];
    can you share a link to a single post where the navigation needs to be removed ?
  • philipperoussel
    Hi David,
    This one, for instance: https://onehomeplanet.com/the-end-of-zionism/
  • Have you tried adding the entire snippet I provided above?
  • Hi Alvind,
    Sorry for the long delay for my answer. I did try the entire snippet you provided, unfortunately it does not work. I also added $excluded_slugs = [‘articles’]; to the original code I have (this one works for what it has to do: showing nav. links), but to no avail.
    Thanks again for your help.
    the method Leo provided should work:
    	 if ( !in_category('articles')) {
    It does not work either.
  • How did you add the PHP code?
    And with David’s code, you need to disable the Display post navigation option at customizer > layout > blog > content > single.
    I added the code in a PHP snippet.
    Disabling the post navigation goes against what I want, which is to have it disabled for specific post categories, not all of them.
  • In this case, you need to disable the post navigation because the snippet will enable post pagination where the current post is not within the category you chose to exclude in the snippet.
    I disabled the post navigation. The following code does not activate post navigation for post categories other than the one mentioned:
    add_action(‘wp’, ‘custom_generate_category_post_navigation’);
    if ( !in_category(‘articles’)) {
    add_filter(‘generate_category_post_navigation’, ‘__return_true’ );
  • Hmmm… something seems to be conflicting.
    How about some CSS to hide it instead ?
    .single-post .category-articles #nav-below {
        display: none;
Viewing 16 posts - 1 through 16 (of 18 total)
