bennyuk2
Is there any date that we can use a post navigation element in GP2 that can show links within the same term (like it does in GP1)?
I can see the old templates make it possible, using the old GP1 method, just not using GP2 method.
Ben -
You can use GB v2 to create post navigation element.
For next post use
{{post_title source:next-post}}for text, and{{post_permalink source:next-post}}for link.For previous post use
{{post_title source:previous-post}}for text, and{{post_permalink source:previous-post}}for link.Here’s an example can be pasted to your block element:
<!-- wp:generateblocks/element {"uniqueId":"125fe0d3","tagName":"div","styles":{"display":"flex","flexDirection":"column","alignItems":"flex-start","flexGrow":"1","flexShrink":"1","flexBasis":"0px"},"css":".gb-element-125fe0d3{align-items:flex-start;display:flex;flex-basis:0px;flex-direction:column;flex-grow:1;flex-shrink:1}"} --> <div class="gb-element-125fe0d3"><!-- wp:generateblocks/text {"uniqueId":"5d4b34be","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em","fontSize":"12px","marginBottom":"10px",".gb-shape svg":{"width":"1em","height":"1em","fill":"var(\u002d\u002dbase-3)"},"textDecoration":"none"},"css":".gb-text-5d4b34be{align-items:center;column-gap:0.5em;display:inline-flex;font-size:12px;margin-bottom:10px;text-decoration:none}.gb-text-5d4b34be .gb-shape svg{width:1em;height:1em;fill:var(\u002d\u002dbase-3)}","htmlAttributes":{"href":"{{post_permalink source:previous-post}}"},"metadata":{}} --> <a class="gb-text-5d4b34be" href="{{post_permalink source:previous-post}}"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 448 512"><path d="M9.4 233.4c-12.5 12.5-12.5 32.8 0 45.3l160 160c12.5 12.5 32.8 12.5 45.3 0s12.5-32.8 0-45.3L109.2 288 416 288c17.7 0 32-14.3 32-32s-14.3-32-32-32l-306.7 0L214.6 118.6c12.5-12.5 12.5-32.8 0-45.3s-32.8-12.5-45.3 0l-160 160z"></path></svg></span><span class="gb-text">PREVIOUS</span></a> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"ada67ae6","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em","fontSize":"20px","marginBottom":"10px",".gb-shape svg":{"width":"1em","height":"1em","fill":"var(\u002d\u002dbase-3)"},"textDecoration":"none"},"css":".gb-text-ada67ae6{align-items:center;column-gap:0.5em;display:inline-flex;font-size:20px;margin-bottom:10px;text-decoration:none}.gb-text-ada67ae6 .gb-shape svg{width:1em;height:1em;fill:var(\u002d\u002dbase-3)}","htmlAttributes":{"href":"{{post_permalink source:previous-post}}"},"metadata":{},"className":"hide-on-mobile"} --> <a class="gb-text gb-text-ada67ae6 hide-on-mobile" href="{{post_permalink source:previous-post}}">{{post_title source:previous-post}}</a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> -
bennyuk2
thanks but there is no option to show ONLY posts within the same term (same category), as there was in v1 post nav element.
Will this be added?
Yes, you are right, the option is gone.
I’ll check if the option will be added back in the future.
So we reviewed the issue and think it’s nessasaery, I’ve raised a feature request, hopefully it will be added in the future update.
For now, use below code to generate 4 new dynamic tags
– Previous Post Title – same term
– Previous Post URL – same term
– Next Post Title – same term
– Next Post URL – same termadd_action('init', function () { if (! class_exists('GenerateBlocks_Register_Dynamic_Tag')) { return; } // Previous Post Title new GenerateBlocks_Register_Dynamic_Tag([ 'title' => __('Previous Post Title - same term', 'generateblocks'), 'tag' => 'previous_post_title_same_term', 'type' => 'post', 'supports' => [], 'description' => __('Displays the previous post title of the current post, in the same term.', 'generateblocks'), 'return' => function () { $prev_post = get_adjacent_post(true, '', true); return $prev_post ? esc_html(get_the_title($prev_post->ID)) : ''; } ]); // Next Post Title new GenerateBlocks_Register_Dynamic_Tag([ 'title' => __('Next Post Title - same term', 'generateblocks'), 'tag' => 'next_post_title_same_term', 'type' => 'post', 'supports' => [], 'description' => __('Displays the next post title of the current post, in the same term.', 'generateblocks'), 'return' => function () { $next_post = get_adjacent_post(true, '', false); return $next_post ? esc_html(get_the_title($next_post->ID)) : ''; } ]); // Previous Post URL new GenerateBlocks_Register_Dynamic_Tag([ 'title' => __('Previous Post URL - same term', 'generateblocks'), 'tag' => 'previous_post_url_same_term', 'type' => 'post', 'supports' => [], 'description' => __('Displays the previous post URL of the current post, in the same term.', 'generateblocks'), 'return' => function () { $prev_post = get_adjacent_post(true, '', true); return $prev_post ? get_permalink($prev_post->ID) : ''; } ]); // Next Post URL new GenerateBlocks_Register_Dynamic_Tag([ 'title' => __('Next Post URL - same term', 'generateblocks'), 'tag' => 'next_post_url_same_term', 'type' => 'post', 'supports' => [], 'description' => __('Displays the next post URL of the current post, in the same term.', 'generateblocks'), 'return' => function () { $next_post = get_adjacent_post(true, '', false); return $next_post ? get_permalink($next_post->ID) : ''; } ]); }); -
bennyuk2
thanks for the update, hopefully feature will be added back soon.
No Problem 🙂
