eluyawi
Hi,
When a user is reading a post, how can configure the post to get two links one of them for reading the previous post and the other one the next post?
in Customiser > Layout > Blog under the Post tab:
https://docs.generatepress.com/article/blog-content-layout/
There is an option to Display Post Navigation
eluyawi
Hi,
I have just activated that option in the blog but the problem I have make a template to show the content and so I think is not displayed the post navigation
I have just activated that option in the blog, but the problem is that I have created a template to display the content, so I think the post navigation is not showing due to the template.
Can you take a look to this screenshot
https://imgur.com/a/gmVIxrF -
If you are using a content template, the default theme post navigation won’t work.
You can create a block element – post meta template, there’re some pre-build template you can use.
eluyawi
Hi
To create the page navigation I have created a block – Navigation through entries.
This block is shown in All entries and in all archive entries, but I can’t get the navigation to show.
But I can’t get the navigation to show, what am I doing wrong?. I want to get that when a user is reading a post, at the end of the article be showed the post navigation.
You can have a look at this screenshot.
https://imgur.com/a/Hj5rAXv
https://imgur.com/a/Hj5rAXvThanks
1. Edit your Block Element Content Template.
2. in the settings sidebar , temporarily change the element type to the Post Navigation.
3. Choose the Template you want to use and add it to the content template.
4. in the settings sidebar , change the element type back to the Content TemplateNow you have a single content template that includes the Post Navigation.
