posts showing raw code for categories and related posts after site migration
  • I just migrated my site to a new host, and while all seems ok in testing otherwise, the single posts pages show some raw code above and below the post content, e.g.
    term_id ) ) . ‘” alt=”‘ . esc_attr( sprintf( __( ‘View all posts in %s’, ‘textdomain’ ), $category->name ) ) . ‘”>’ . esc_html( $category->name ) . ” . $separator; } echo trim( $output, $separator ); } the_title( ‘
    ‘ ); if ( has_excerpt() ) : // Only show custom excerpts not autoexcerpts ?>
    Not sure if I have a corrupt theme or code or child theme?
    If you swtich to the parent theme, do you still see it?
    And you can also try disablling all plugins to test as well.
    Let me know how it goes.
  • Thanks Ying, themes made no difference but disabling GP Premium did remove the code. I renamed the plugin and uploaded a new copy but the problem returned. Thoughts?
    Dave
  • For now, I have removed the elements from the post pages but would like a solution if we can think of one. Thanks for your prompt response and support
  • Activate GP Premium, then go to appearance > generatepress, disable all premium modules. Is the issue fixed?
    If so, enable the modules one at a time to see which one is causing the issue. I guess it’s the Elements.
    If so, disable all elements, if the issue is gone, enable elements one at a time to see which element is the cause.
  • Thanks, it was two of the elements for single posts, I took them out of display rules and it’s OK.
    Dave
  • Glad to hear that 🙂
