Hi Team GP, I’m trying to achieve this – My API creates new sites as custom post types. Now I want, when a new site is made, that it takes the pattern I made, like a template. I tried elements with layout, but there is no way to add the pattern. Should I try a hook (inside content), but what to insert? Something like <!– wp:block {“ref”:3430} /–> which is a reusable block?
Any ideas, on how to setup a page before the API creates this site?
Thanks in advance. -
I’m not sure I understand your question, can you explain some more or with some examples?
Hi Ying,
I have CPT – Custom Post Types – for a hotel. 1 for rooms, 1 for offers.
Workflow now: The API creates a page inside the CPT from a json-file and fills the content into customfields.
Than I have to go to this page, insert a pattern/template which corresponds with the customfields and makes so a perfect page.
What I want. When the API creates a page, the template/pattern should instantly be in this page, so the page looks nice, without touching it.
So, I’m trying to achieve – When a page is created in the CPT ‘offers’, the pattern/template should be in this page. The pattern/template is always the same.
What I tried: Elements with hook, generate before main content – does nothing.
Elements Layout – no fields for prefill.
So, what should I do, that when a page is created, the pattern/template is there – kind of prefilled? -
I got it, what you need is a block element – content template.
https://docs.generatepress.com/article/block-element-content-template/You can pre-build the layout, and dynamically pull the content/title/custom fields via GB’s headline/button/container.
However, the content template won’t show in the post editor, it only shows the result when the page is previewed or published.
content-template is for posts only – no function for sites or custom post types.
Anyway, I made it with elements – block – generate_before_footer and this works.
As you mentioned you cant see it in the backend, but in the frontend it shows up.
Thank you. -
No, you can assign it to CPTs as well.
The content template can be used on single posts, single pages, single cpt, all archives and blog 🙂
xxtita
How?
Elements > Block
Content Template = ok
And them? Tag name > div
Apply to > Posts with term (All posts, first post, post with custom field – don’t work)
Taxonomy > ?
Term Name > ?
Parent Element > ?
Do you know which config is needed to create a content template before the API brings data to the CPT?
Thank you. -
CPT > All CPTS
should work. -
xxtita
Should work, but is not there.
So i added an additional category to the cpt, so at least the category is visible, but has no effect on the template.
Because i can not add the category before the API makes the cpt.
As i already mentioned, there is a workaround, but still curious – keeps me awake;)
You should add it through the Location settings. If your custom post type is named “Hotel,” then select “Hotel > All Hotels” in the Location dropdown.
xxtita
” alt=”detail” />
No CPT available -
xxtita
xxtita
looks like imgur and imgbb not working
that is not the correct place.
You need to set the Display Rules Location. See here: -
xxtita
Settings for this topic:
Elements > Block > Content Layout – Dont touch any settings (if you want to apply it to a CPT)
and choose the Localization where it should appear. -
Did you see the screenshot o provided?
You need to set the Display rules Location to match your post type.
