BennyO
Hi Team,
I have been struggling for two days to get your theme work.This is a link to my staging site after showing the blog post from the “Explore” theme.
It seems GB und GP CSS are not properly loaded. I also tried the “Elegant” theme. Same issue.
I created simple blocks on a new page and post with GB. Same issue. CSS not loading?Blog Post from “Explore” theme on my staging site
It is urgent. I am running out of time.
B.O -
Can you check your customizer > colors, do you have those colors set:
contrast
,contrast-2
,contrast-3,
base
,base-2
,base-3
,accent
?Let me know 🙂
BennyO
Hi Ying,
those colors are there. This was not the point.Elements are missing CSS, GB css is also missing. It seems there are not pulled.
Please have a look at this sample page (imported from the elegant theme) as well as a sample page I created using
GB pattern (hero 13).This is not my first GB/GP installation. I am pretty familiar with your product.
Imported site from Elegant theme (credits page): http://57182224.swh.strato-hosting.eu/wordpress_clone_WordPress_SecureMode_01/credits/
My own sample site using GB hero pattern (hero 13): http://57182224.swh.strato-hosting.eu/wordpress_clone_WordPress_SecureMode_01/testpage/
If i check your Portfolio page, i see the request for the GB dynamic styles
https://storage.googleapis.com/stateless-styleappetite-com/2023/06/generateblocks/style-65.css?ver=1685795799
And that request is 404ing.
Probably because GB saves the files in the/wp-content/uploads/
folder.Do you use any code or functions that change where your media attachments are saved ?
BennyO
Hi David,
Thanks for reply.
Yes, I am using a plugin called “Stateless plugin” to which pushes uploaded media to Google Cloud Service.Photographs are also served from GSC.
So I am bit lost on why CSS file is 404ing.Regards.
Should I open a topic with the GB team?
We combined the forums so no need to ask anywhere else – GP and GB support are here 🙂
Sorry its a 403 Forbidden error that is being returned.
So that storage server isn’t, allowing access.Can you check with the stateless plugin author as to why that may be ?
