Anonymous
The width is not standardised , it is affected by content length
Ie shorter sentences in one card relative to the other would make that card appear narrower.
If you want the columns to have the same width, you can simply set a fixed width for each container. This ensures they won’t inherit the width based on their inner content.
Anonymous
Feedback: this is a Pro service, I would expect the pro patterns to work out of the box. This is not a bespoke custom development request but basic expectation of design consistency.
I would escalate this to your design team for correction.
You are still using the v1 legacy patterns. Can you switch to v2 and use v2 patterns? I believe v2 patterns don’t have this issue.
Anonymous
How can I switch to V2 can’t figure it out. I ahve disabled V1 via Geneateblocks > Settings, issue persists.
Have you tried inserting a new pricing pattern from the pattern library? I’m still seeing the v1 pattern on your page.
Anonymous
I have inserted a new pricing pattern, same styling inconsistency.
Your site is in maintenance mode, I can not see it anymore.
Anonymous
should be up again
I’m still seeing the v1 pattern:
https://app.screencast.com/Ly2jTfLCvc5QA -
Anonymous
Thank you, that V2 now I think.
I can’t seem to get all 3 cards on the same row, could you advice please? At present, the pricing cards occupy 2 rows.
The page you linked is a 404, can you check?
Anonymous
Apologies Ying, the issue was sorted and the archived!
Thank for your support in sorting this 🙂
Glad to hear that 🙂
