lune856
Created a page then added pricing plan table (premade template from Generatepress). Changed a few texts and boom this is what I’m getting. Please help
select the problem button block and in the block settings ( or toolbar ) set the Alignment to Default instead of Full Width
lune856
Thank you David, that worked like a charm. Kudos to you!
(Why did that happen in first place though? I merely just dragged pre-made template to my page.) -
Those Patterns are not added by GeneratePress, they are from WordPress core and use core blocks.
So it look to be an inherent issue with that particular pattern as they choose to use the Full Width align option which is interpreted differently by different themes.We recommend using GenerateBlocks for building layouts and its own Pattern Library.
As those you have a lot more control over their layout then core provides
