Primary navigation doubled
    I changed the navigation setup with the scope to speed up my site.
    Now I use only the primary navigation with breakpoint 768 and the off canvas panel for mobile only. As far as I can see it works fine on mobile. But on desktop the navigation is doubled, once the desktop setup without navigation logo and in addition the off canvas setup with navigation logo. What is wrong?
    Screenshot
    The menu layout seems fine now. Did you manage to fix it?
  • It’s not all time the same. I no longer see both menus as in the screenshot, but I often see the mobile menu and the desktop menu below it for some millisecond. The mobile menu disappears immediately and the desktop menu shifts to the top. It looks as if both menus are loaded.
  • It looks as if both menus are loaded
    That is the case, all those menus are in the HTML, one is hidden with CSS.
    If you are seeing that, it’s likely due to cache.
  • I see it also in the incognito mode of the browser and with the cache cleared.
  • Could you try disabling the Mobile Header in Appearance > Customize > Layout > Header first?
  • Now happens this screen record
  • I mean try with cache plugin disabled, not just clearing the cache.
    Let me know!
  • There is no cache plugin. Before the screen record object cache and Ezoic cache were cleared. I continue to see the problem and I believe you can see it also on your side.
    Moreover, this is the situation after the changes proposed by Alvin. Cache problems are therefore excluded.
    Then do you have server level cache enabled? As when I see the CSS, it’s the cache of ezoic, not the original CSS from the theme.
    Do you mean disabling the mobile header? It’s the same issue that the browser loads the HTML without style before it loads all the CSS.
  • Then do you have server level cache enabled? As when I see the CSS, it’s the cache of ezoic, not the original CSS from the theme.
    I don’t know what server level cache is. You see the Ezoic Cache but the screen record is taken bypassing Ezoic
    Yes, after disabling the mobile header the browser loads for the firt moment without style, as you see in thr reocrd. Before disabling it the problem was that mobile and desktop navigation were shown both for a moment.
    To bypass Ezoic, ýou must address the IP indicated in the private section.
  • Have you attempted to check your site in a different browser? It might be a browser cache issue. Check out this screen recording of my view; the menu layout is perfectly fine:
    https://app.screencast.com/DJYXf1rs8swaE
    thank you for the screen record. You can see it once at 00:25 and then again. Here is a screenshot from your record at 00:25
    https://ibb.co/MNfYpw1
  • Wow, I didn’t catch that.
    If possible, could you provide temporary login credentials for your site so we can take a closer look at what’s going on?
  • I added it to the private information.
  • Check this screenshot, as I said you haven’t disabled all your cache yet.
    https://app.screencast.com/N7pqNPcMuXWcq
    I also noticed that you’ve enabled the sticky nav, but it’s not sticky. Do you know what’s going on?
    By the way, the login you sent can only allow us to see the front end, I’m still not able to see the back end.
Viewing 16 posts - 1 through 16 (of 26 total)
