My website is diligentworks.com
I just switched from divi to optimize press. Trying to use both Divi and optimize press together, so I have the GP theme and the divi plugin.
My Primary navigation is not working showing on the website.
I have disabled all plugins, I checked to be sure I didn’t disable the primary navigation on each page. I have tried many things on the forum that didn’t work.
Hello there,
What’s the login link?
Moreover, I tried checking the site you linked and it doesn’t seem to be using the GP theme. Can you check?
If you temporarily disable Divi, does the nav appear?
Nope, it doesn’t. I tried doing that.
Can you try #1 here to debug: https://docs.generatepress.com/article/debugging-tips/
It’s recommended to backup your site before proceeding with this.
