Prime theme
    I am working in your Prime theme, but I can not change the footer text.
    Normally it is layout footer. But when I take the standard route, the normal cube there is to add/edit footer text does not show. I can also not find the info in custom cc.
    Do you know why?
    Kind regards,
    Pascal
    go to Appearance > GeneratePress and activate the Copyright module.
    Then you can edit it in the Customizer > Layout > Footer
  • Thank you. Solved it.
    Last quick question (A men can always hope), At my homepage in the Amazon theme, the gallery sliders show incorrect. Do you know why?
    http://www.tropico-diffusion.fr
  • Its because of this CSS:
    body:not(.single) .inside-wc-product-image {
            width: 300px;
            height: 300px;
            overflow: hidden;
            display: flex;
            align-items: center;
            margin: auto;
    its forcing the images to be 300px wide – when there is no room for them.
    Do you need that CSS ?
  • No need for that css. Solved. Thank you.
  • Glad to hear that
