Problem with back-to-top button
    My anchors don’t work properly with classic buttons in my pages.
    When I click on the back-to-top button, the page rises very slowly and is difficult to access.
    No problem if the internal anchor is in a navigation menu (but difficult to modify in css).
    I tried deactivating the smooth-scroll class in the theme customisation, but it didn’t work.
    Do you have a solution?
    It’s because you have this CSS is which interfering with the script of the back to top’s smooth scroll.
    html {
        scroll-behavior: smooth;
    Try this PHP snippet to remove smooth scroll from the back to top button://remove GP smooth scroll from back to top button:
    add_filter( 'generate_back_to_top_js_args', function( $args ) {
        $args['smooth'] = false;
        return $args;
  • It’s perfect.
    Thank you for your support, which is always responsive and provides the right solution! 😉
  • You are welcome   🙂
