Problem with creating Element, only title showing
    We’re on a development website and we can’t create new elements like layouts. When we add a new layout it only shows the title.
    Turned off all plugins and switch to default new fresh installed GeneratePress theme.
    No errors in the console. Only GP Premium active as a plugin.
    Regards,
    Kees
    Edit: temporary fix is creating new admin.
  • Great to hear that 🙂
    Anyway, while inside the Element editor, have you checked under the Screen Options at the top right to see if the “Display Rules” option is unchecked?
  • It is checked. But both checked/unchecked no changes. Still invisible options.
  • Thank you for confirming. It seems we’ll need to investigate this issue further since it’s already affecting multiple users.
