Problem with header elements
  • Hi, i have a problem with my header elements, I did some small changes by mistake and now I cant get header to work properly, i am having problems understanding how it works. My navigation and logo is for some reason above my header, and is causing major problems in layout. I am sending you login info in private, if you can have a look I would be very thankfull, it is difficult to explain.
    It looks like the Merged Header element is missing from your site. Did you happen to delete it? The Realtor template relies on that element for its header layout.
  • Yes, is there a way to get it back?
  • I could really use your help to get the header on home page and rest of the site back to normal behaviour, because I cant figure out how it works. Thank you.
  • I have recreated the header element for you.
  • Hi Ying,
    thank you but I still do not see the header as it was. My homepage has an extra “element” on top, and navigation is not visible on the header like in the demo site. Please help.
  • You have an element called Global page header, is this the extra element you were referring to? If so, remove home from its location.
    And you also disabled the header for the homepage from the layout metabox:
    https://app.screencast.com/SIxOnl0URrnG4
