Problem with styling
  • Hey there,
    I have a problem with styling images and containers, in my dashboard it looks exactly how I want to see it,
    https://ibb.co/Y0N4r7j
    After I publish it, it’s just default image placement, without any styles, here is the result image:
    https://ibb.co/hM9jr5y
    I’ve tried to disable the caching plugin, but the results are the same.
    What am I doing wrong?
    it’s likely due to the image optimizing plugin, it’s using picture tag which GB image block does not support.
    Can you try disable the picture tag in the plugin?
    Let me know if that helps!
  • Hi Ying, fixed, Thanks ))
  • No Problem 🙂
