Problems setting Home and Blog pages in Volume site from site library
  • Hi- I selected the volume site from the GP Pro site library and just imported it. It seems to be working well but I’m having problems with the home and blog pages. Here’s the full description:
    1. I changed all template posts to unpublished so there are not any current posts published.
    2. I published my Home and Blog pages so these are the only two pages published.
    3. I went to Appearance –> Customize–> Homepage Settings and changed the displays to A Static Page and selected Home and Blog for each respectively.
    4. Then, here’s the problem:
    A. When I go to the Home page, the map that I have coming through as a Block-Hook from Elements isn’t showing up.
    B. On the Blog page, all of my content is gone and instead the Blog page is showing the latest blog post (I only have one published as a test).
    Both the Home and Blog pages work fine before I set them as Static and all of my page content shows on them before setting them in the static option.
    Thanks for your help!
  • Hi Jferguson,
    A. What display rule settings did you set for this Block Element? Also, where is it hooked to?
    B. What content are you referring to? Are these other Posts? Or, do you have Elements not appearing?
  • Let’s focus on the Blog page issue, I figured out the issue with the hook on the first page.
    The only posts are samples that come with Volume. So the issue is that even after creating a unique Blog page and pointing Blog to my Blog page under Homepage Settings, the template page is still showing when you click the Blog section on the menu.
  • I see. Can you provide admin login credentials through the Private Information field so I can take a closer look at your setup?
  • Thanks, creds in the private message
  • Attached
  • Would you be able to temporarily disable the 2FA instead and then reenable it after we check the site?
  • Yes, ready for you
  • Sorry, what’s the login link by the way?
  • below
  • Sorry, I’m confused. The Blog seems to be working fine.
    What exactly is missing? Or, are you wanting to replace the template? Can you try re-explaining the issue?
  • Sure. First, go to pages and look at the Blog page. You’ll see the page that I’ve created, along with a button on the bottom to go to the Family Gap Year page. Then, go to the home page and click Blog in the header. None of the content from my Blog page appears there. It seems like there’s an Element or something else that’s overriding the Blog page content. Thanks.
  • This is the site I’m looking at: fivebylandandsea. Is this the correct site?
    There are two templates working on the Blog page – one for the first post and another for the other posts. They are “Post Archive Template” and “First Post Template”. They are working fine.
    For clarity, can you share screenshots of the issue? Uploading Screenshots: https://docs.generatepress.com/article/using-the-premium-support-forum/#uploading-screenshots
  • See message below, thanks
  • What you’re trying wouldn’t work. You’re editing it on the Blog Page itself which wouldn’t work for the Blog page since it’s a dynamic page. That would only work for static pages
    Are you just wanting to add that top portion? If so, just create a Block Element – Page Hero. Reference: https://docs.generatepress.com/article/block-element-page-hero/
  • Thanks. I added the Page Hero Block Element and it works great when blog Posts are published but since I currently don’t have any published, it shows my Page Hero element and then “Nothing Found.” Is there a way to solve that until the first post is published?
Viewing 16 posts - 1 through 16 (of 19 total)
