Problems with Blog Template “info”
  • Hello everyone, I use the template “info” and have the problem that a single post is always displayed in all categories on the homepage.
    No matter how I configure it!
    Normally it should be the case that you write a post for travel tips, for example, and it should then be displayed in “one” of the designated categories on the homepage and not a post in all categories at the same time – unfortunately that doesn’t work the way I would like – could you please help me with instructions?
    Thank you very much for your effort!
    Best regards from Germany
    Jurgen
    Is that post a sticky post?
    Can I see your site?
  • Hallo Ying,
    yes gladly
    https://www.bootskultur.com/
    Greetings
    Juergen
  • Oh the issue is that none of the query loop blocks on the homepage has been configured.
    We don’t do configuration for query loops in the site templates as it adds too much load time for the users, so we encourage users to do the configuration after they import the site.
    Here’s an example of how you configure the query loop blocks:
    https://docs.generateblocks.com/article/query-loop-examples/#posts-in-a-category-or-categories
  • Hello Ying, unfortunately it didn’t work and since my terms and content are all in German, I honestly don’t know whether I was looking in the right place for the settings. Would you please tell me where I can find the function to change it, as unfortunately I haven’t found it yet. Thank you for your effort! Best regards
  • Select the query loop block, and you can find the settings in the right sidebar of the editor.
    If you can provide an admin login, I can take some screenshots for you 🙂
  • It took a while 🙂 but I managed it thanks to your solution. Thank you very much for your helpful support! Many greetings from Germany! Juergen
  • You are welcome Juergen 🙂
    It’s our pleasure to help!
