Problems with columns after update
    we have a problem on one page after updating GP Premium and GenerateBlocks/Pro. After the update, for example, the width of the article listing on the home page is messed up, somewhere the column widths are changed. For example it changes from 33% to 100%. On the home page for the article listing, the indentation from the margins will also change. I am also sending screenshots where the problems appear. In one of the screens you can see what current versions of plugins we have. Can you please advise me?
    Thank you
    Have you resolved the issue? I just checked the home page and everything looks normal to me:
    https://www.screencast.com/t/wKZajoMt
    this web status is before updates. The site is live and can’t leave it “broken”. In the screenshots I have posted the before and after update states. The screenshots also show what plugin versions we are on.
    do you have the option to create a staging site where we could see the issue ?
    unfortunately, we don’t have the ability to create a staging site. I can create you access to the live site if you want.
  • Before we go there:
    You have 3 grids, one with 33.33% width
    And the other with 40% and 60%
    When you update the plugin do both grid columns lose there width values in the Editor ? Or is it just the 33.33% ?
  • From 33.33% it looks like it becomes 100%, but it’s not visible in the settings.
  • In your screen shot the it looks like it is set to 33,33% ie. it has a comma between the numbers
    It needs to be a decimal point ie. 33.33% – can you change it to that ? And then see what happens when you update ?
