Problems with Explore template
  • FYI there are (at least) a couple of problems with the mobile version of the Explore template in the site library.
    1. The post heading on mobile view goes off the page rather than shifting to a mobile view – how do I fix that?
    2. The social icons at the bottom of the footer all crumple up together on mobile – I can probably fix that myself!
    Thanks.
  • Hello there,
    1. Can you share a screenshot of this issue from your end? I tried accessing your site and from my end, it isn’t going off-screen.
    2. You can edit the Block settings of these Buttons on mobile. Just select the mobile icon on top of the mobile settings.
    Then, give them a width of 25% so they fall on one line.
    I’ll also report this issue to our team.
  • Example from the new installExample from the Generate Press site library Explore template
    Thanks – here are two examples. It’s the blog post headline on the Explore template in MOBILE view.
  • Thank you for pointing that out. For now, you can set the width of the Container Block to 100% holding the Heading from the Block Element on mobile.
    That should prevent the issue from happening. I’ll also mention this to the template developer.
  • Yes, that’s fixed it, thanks.
  • You’re welcome! Our template developers have also fixed the issue from the template upon importing. Thank you!
