Good Morning
On my Claybright site, all the product photos are too large and on the right-hand-side, enlarges the text and cuts off the enquiry button and omits other information. See https://claybright.co.za/product/cam028-kam028-lam028-bay-blue/ for an example.Yet on my Cape Pottery Supplies (which is a similar site in layout and plugins) site see https://www.capepotterysupplies.co.za/product/teapot-book-cased-jacket-hor070/ where the product and information and enquiry button follow the correct layout and appear perfectly throughout the site.
Can you advise?
I’m using the plugin Enquiry Quotation for WooCommerce Pro for my Enquiries.
I hope this makes sense and contains enough information?
Thanking you
Can you try to reduce the Product Image Area Width in the customizer?
https://docs.generatepress.com/article/woocommerce-overview/#single-productLet me know if this helps 🙂
Good Morning Leo.
Thank you for your reply. I don’t have those options in my customizer as per your link. I never set up my shop using GP Woocommerce.
I’m using the plugin Enquiry Quotation for WooCommerce Pro for my entries and Enquiries, so my whole shop is based on that. Funny that it should work on the other sites as per my links above.
Could you have another look for me please?
Axel -
There is a different HTML structure between the sites, which explains the variation in output. See here:
This may stem from the WooCommerce settings themselves, as there is no indication that the theme is interfering with the image output.
Please see additional private information post.
Thanks Axel
Thank you Alvind.
This is strange as theses are cloned sites?
1. go to Appearance > GeneratePress and make sure the Woocommerce module is activated.
2. go th Customiser > LAYOUT > Woocommence and set the Product Image Area Width to 50%. NOTE: that the setting is in the Layout > Woocommerce panel.
