nfedesign
I have a page that at the bottom I want to show all the products in the category (currently 35)
There is 1 parent category, and 6 child.using the “products by category” I have selected the 6 child categories. The problem is it allows only a max of 6 rows. Is there a way to allow more?
https://greenessentials.com.au/lunch-eating-out/
Note I know I can allow more columns but I don’t really want them to display any smaller (and even putting that to the max wont allow all the products. As it is all the products wont show on the page.
I guess I could create it twice and put 3 child categories in one and 3 in the other but the issue then is that some products are in multiple categories…thanks!
It would be best to reach out to WooCommerce support regarding this. WooCommerce WordPress forum: https://wordpress.org/support/plugin/woocommerce/
But, if you add your Products by Category Block through a Shortcode, it seems possible. Example of a shortcode:
[product_category category="clothing,accessories,hoodies,tshirts,courses" per_page="12" columns="3"]
You can add this through a Shortcode Block.
nfedesign
Actually, I think what it needs is a “next page” option. I haven’t had much luck with woo commerce but will keep searching.
The above shortcode does work Fernando, but again, it needs a code for the page turning otherwise you just need to pick a number above the number of products you have and say for example 100 per page. Showing them all at once I am assuming will slow the site down
you can read more info on the woo shortcodes here:
https://woocommerce.com/document/woocommerce-shortcodes/
there are a lot of parameters, including
paginate="true"
which you can add to your shortcode.
