Pulling images form ACF field using dynamic data
    I have come across this a couple of times and am not sure what I’m doing wrong.
    I have an ACF group with about 15 fields, including 2 image fields.
    I’ve then built a template pulling data dynamically into those fields using the dynamic data function. For all text and text area fields, I have no trouble but I seem unable to pull through images using the same methodology.
    Are the parameters I’m using not correct for images?
    What is the Return Format set for those ACF image fields?
  • It was set to Image Array. I updated to Image ID and it worked!
  • Glad to hear that!
