George
I manage a site with a lot of menus and submenus and I was wondering if there was a way to shift some of them higher up the page below the header for desktop. Attached is a video from my client and the site in question.
Hi George,
Try adding this through Appearance > Customize > Additional CSS:
@media (min-width: 1025px){ li.menu-item-has-children{ position: static; } }
George
Hi Fernando, yeah, it’s not bad, but there is an issue with the second level submenu link that is at the bottom not having access to its contents, have a look at the attached video.
odd what happens if the very last menu item has no children, do those sub sub menus work?
George
Hey David, not sure what you mean. They are single post links. But even if they were just blank links, it’s not a thing related with the issue, is it?
The issue seems to be the last item having a sub menu.
If you re-order that menu so the last menu item does NOT have a sub-menu.
Does that fix the issue ? -
George
Hey David, maybe you have an idea because I live in the Twilight Zone again! That particular sub-menu works fine as long as it’s not the last or the one before last in the submenu columns! In those cases, it’s impossible to select it’s children.
It is very strange.
I moved them around in the dev tools and thought it was odd lolIs that a solution then? ie. re-ordering the menu items.
As I am not sure where to begin debugging it otherwise 🙂 -
Yeah, I guess so, I deactivated that functionality just for that menu item, so weird!
Thanks, David.
